Hi guys got a new FFCP, its fitted with the novel cooling fan and duct on the side, how do i control this to turn it on and off for ABS?
Im using Makerbot DT printing via SD
thanks
thanks
I struggled with the same thing. In Makerbot Desktop 3.7.0.95 select Settings, then down in the lower right corner of the Advanced tab is a button called Edit in external editor or something like that. Click that and a file called miracle.json will open. There is a miracle.json for each printing profile you have. There will be a whole list of parameters in there. The ones you need to add are:
"doFanCommand" : true,
"fanLayer" : 2,
Once you save your settings file. You'll immediately see new controls that let you turn cooling on and off and set the layer.
