5 Attachment(s)
Stratasys uPrint SE plus 3D printer
Included: Printer, material bays, power cables, software (can include part washer upon negotiation)
Price: $18,300
Condition: Used but still in very good condition, sold as is
Buyer must be in San Diego or willing to travel to our facility in order to pick up the printer after purchase.
Printed parts pictured were printed using this machine.
Manufacturer information:
http://www.stratasys.com/3d-printers...uprint-se-plus
“The uPrint SE Plus 3D printer uses Fused Deposition Modeling (FDM) Technology to build in real ABSplus thermoplastic, creating models and functional prototypes that are durable, stable and pinpoint accurate. With nine colors to choose from, you can create realistic prototypes and marketing models. Use them to evaluate form, fit and function in everything from ergonomics to manufacturing processes — right from your desktop. Two layer thicknesses let you choose whether to print your model 30 percent faster or at a finer resolution. Optional dual material bays mean more uninterrupted print time, so you can maximize productivity even when you’re not in the office.”
Model material:
ABSplus in ivory, white, blue, fluorescent yellow, black, red, nectarine, olive green or gray
Support material:
SR-30 soluble
Build size:
203 x 203 x 152 mm (8 x 8 x 6 in.)
Layer thickness:
.254 mm (.010 in.) or .330 mm (.013 in.)
Workstation compatibility:
Windows XP/Windows 7
Network connectivity:
Ethernet TCP/IP 10/100 base T
Size and weight:
uPrint SE Plus with one material bay: 635 w x 660 d x 787 h mm (25 x 26 x 31 in.), 76 kg (168 lbs.)
Power Requirements:
100–127 VAC 50/60 Hz, minimum 15A dedicated circuit or 220–240 VAC 50/60 Hz, minimum 7A dedicated circuit
Attachment 1779Attachment 1778Attachment 1777Attachment 1775Attachment 1776
