5 Attachment(s)
New materials, now free samples are available.
Our company just announced new kinds of nylon filaments, we've done special modification on polyamide (which also called nylon), which is definitely different from some normal nylon made from Taulman. However, it still keeps the extraordinary properties of nylon, good heat resistance, excellent abrasion resistence and high toughness. More importantly, this nylon material has very low shrinkage rate and smooth appearance. Normally, you don't need to polish objects with difficulty since its support material is easy to remove and its smooth surface. Using this nylon material, large size and sophisticated industrial structure can be made with quality. Two more things you may concerned.
1. No Warp
We have done chemical modification on nylon so it won't warp under the settings we recommend . The bed adhesion is very good and printing operation is simple.
2. less moisture
Moisture always annoyed us during printing nylon. Our nylon filament has less moisture absorption. In fact, we have tackled this problem very well.
Here are some models using our nylon filaments(most of them have no post processing or a little bit).
Attachment 6396Attachment 6397Attachment 6398Attachment 6399Attachment 6400
These models are all printed by our YMe 3D printers. you can see it in another link.
Our nylon filament now has two grades , You can get free PA B330 sampleshttp://forums.reprap.org/mods/smiley...es/smilie1.gif
Engineering Grade : PA B380 Print temperature: ~260oC bed temperature : at least 110oC Enclosed environment is required .You must utilize YMe 3D printer to print this grade, which can provide excellent quality of objects, smooth surface, high strength and toughness.
Commercial Grade:PA B330 Print temperature: ~250oC bed temperature :110oC Enclosed environment is required .This grade can be used in some common printers but your printer should still be good enough. So please email me your machine type and picture. we will post you free sample if we think your machine is capable of printing our filament. You just need to pay the shipping fee.
Notice: We would post you from China and it costs shipping fee and needs some days.
If you want to know more our products or have any queries please contact me . My name is Henry liu. Email address: liuyudehaoa@163.com tel:+8615011815569 Company:Guangzhou YMe Advance Material Technoligy Co.,ltd, China
