You add supports (generally just vertical columns) from the print bed to where the trunk is (like in this picture), then remove that (e.g. with diagonal cutters) after the printing is done, then smooth up the print so it looks like they were never there.
Attachment 588
Smart software will add the supports for you.
This is one of the main attractions of dual-extruder printers. You can have it print the supports in a different material, specifically,
one that will dissolve away so you don't have to do the cutting and extra finish work that entails.
