Results 1 to 6 of 6
Thread: converting STL to .ipt
12-29-2013, 01:15 PM #1
- Dec 2013
- 8
Does anyone know how to take an STL file in inventor and convert it to a solid in order to edit it?
12-29-2013, 03:54 PM #2
- Nov 2013
- 48
I know you can import STL files by choosing the file extension .STL from FILE>OPEN. I don't believe you can edit it with as much power as if you modeled it from the ground up. When opening STL in inventor it sees them as a mesh. I'm not sure if Inventor can edit mesh files with ease. You might be able to add and remove geometry but I am unsure how.
Autodesk has a free software called Meshmixer. Maybe that can help?
12-30-2013, 09:46 AM #3
- Dec 2013
- 46
Aaron, what is the reason you want to convert an STL file to an IPT?
01-04-2014, 05:31 PM #4
- Dec 2013
- 8
NJ_Lifer, not sure why it matters, but I want to make this conversion due to different and incompatible CAD programs.
01-17-2014, 06:12 AM #5
- Sep 2013
- 35
I too would like to do this. Anyone find a solution yet?
01-18-2014, 05:19 AM #6
The transition from mesh-surface to CAD-model is very hard and there are software out there that can do the conversion. Some of them only gives you a "dead" surface (NURBS) model of the stl file. But some even gives you the correct volume that can be edited afterwards. There is some manual process usually, but still beats creating a new solid-file from a STL. The only software i know of and have tried is Geomagic Studio, where I process alot of 3D-scans (mesh files) into STEP/IGES files. Almost always "dead" that is just a bunch of trimmed NURBS-surfaces put together. The more parametric models are still a unknown territory for me, but the software hos support for it.
The only problem is that Geomagic is about 25k USD...
QIDI Slicer "Plater" is...
