Results 1 to 5 of 5
Thread: z coupler
12-21-2014, 09:41 AM #1
- Dec 2014
- Canada
- 498
z coupler
I noticed that maker farm sells metal z coupler, the kit just includes clear tubing. Should I upgrade to using the coupler instead?
12-21-2014, 09:43 AM #2
- Nov 2014
- 522
the clear tubing works fine, you might have to put a zip tie on it if the z rod starts unscrewing out of the tube. one of mine did that i just put a zip tie on it as tight as i could get it and it hasn't had any trouble since.
12-21-2014, 11:40 AM #3
- Jul 2014
- Eastern Colorado
- 536
If you get a metal Z coupler, don't get the ones from MakerFarm. They are hard to get tight on the threaded rods. Get these instead, they have a set screw, while the ones from MakerFarm just squeeze around the shaft. http://www.amazon.com/gp/product/B00M4VNAPA
12-21-2014, 03:16 PM #4
Throw the tubing away and get the type of coupler that AbuMaia suggests. Eventually the tubing loses its tension and your Z-axis doesn't move properly.
Old Man Emu
12-21-2014, 03:58 PM #5
Just to elaborate - it isn't just the MakerFarm metal couplers that are troublesome. Many of the sources out there are the same type, and sometimes the description isn't clear. The issue is with any of the ones that have split ends - that is usually something you can see in the item picture. The problem with them is a screw is used to pull the split end of the coupler together, clamping onto the installed shaft. The one's we need would be intended for use on 5mm shafts, but due to threading tolerance our the M5 threaded rods are less than that - mine measure about 4.8mm. It can be tough to tighten the clamp end enough to grip the threaded rod, but people have done it. Some people also add a layer of foil or foil tape on the end to "thicken" the threaded rod.
The one's like AbuMaia pointed out don't have the split end. They have two set screws on each end and can easily grip the threaded rod, although it might be a fraction of a mm off centered in the coupler when it is tightened. The best compromise is to use the set screw type couplers and still add a layer of something on the rod to help keep it centered in the bore of the coupler.
AI generated 3d models -...
04-12-2024, 11:54 AM in 3D Modeling, Design, Scanners
