Results 1 to 5 of 5
11-27-2013, 06:51 AM #1
Firmware Update - error, can't get it working
Hi, I can't seem to get my E3D to get a firmware update to work, but I keep getting the following error:
avrdude: stk500_getsync(): not in sync: resp=0x89
Any idea what this is? What could be causing it?
12-05-2013, 07:42 AM #2
- Sep 2013
- 36
Have you tried starting from scratch? That's what I'd suggest. Can't think of any other solution.
Jan
12-09-2013, 04:58 AM #3
- Oct 2013
- 34
Which Solidoodle do you have? if you have SD2/3 you can use this guide at least.
Also dont forget to edit the max allowed temp as E3D will run a much higher temp with the 12W heater, thus allowing for way faster extrusion speeds (mind the fumes though)
12-19-2013, 04:15 PM #4
12-27-2013, 07:23 AM #5
- Dec 2013
- 35
I'm having a similar issue. Mysli, could you please explain what you mean by "this guide"?
