Page 11 of 40 FirstFirst ... 91011121321 ... LastLast
Results 101 to 110 of 396
  1. #101
    Engineer
    Jul 2014
    Location
    Eastern Colorado
    Same, I think. It's the one I got from MakerFarm in their 8 inch i3 kit.
  2. #102
    Technician
    Jun 2014
    This issue is certainly beyond my paygrade to figure out then. I have no idea why there would be different behavior with the same hardware/firmware. I'm sure there is a logical explanation, I'm just not the guy that's going to figure it out. That being said though, I am very happy with the way ABL is working. I find the first layer to bed adhesion has dramatically improved for both ABS and PLA and now I don't use any tape, glue or hairspray for PLA at all and just glue stick for ABS. If I use glue stick with PLA, even after allowing to cool below 30c I have to use a blade to remove the part. Very happy with this.
  3. #103
    Engineer
    Jul 2014
    Location
    Eastern Colorado
    It tells me that the sled docking offset is likely a red herring, and the real bug is somewhere else, some setting that I have different or am not using at all.
  4. #104
    Technologist dacb's Avatar
    Aug 2014
    Location
    Edmonds, WA
    This is interesting. So if you don't define it you get a build error or a runtime error?
  5. #105
    Technician
    Jun 2014
    Quote Originally Posted by dacb View Post
    No, it compiles fine and runs fine except it performs a G28 properly, including raising the Z probe at the finish and then does nothing when it should be starting the G29 routine. I had this same issue when setting up ABL a little over a month ago and found the answer in a thread where someone else had the same issue. He uncommented that line and everything worked from then on. I had the same behavior and the same fix worked for me also. I haven't altered any file other than the few changes required in your fork in the configuration.h and the issue was there again. I had done hours of searching over a month ago to find a solution, so applied the same solution and had the same positive result with G29 running normally. I had assumed this must be a common issue, but from Abu's reply I'm guessing this is not common at all. The only changes I made that may not have been standard in the configuration is changing travel limits after homing #define Z_MAX_POS 250 (your build had a value of 235) and commented out Z_SAFE_HOMING.
    I have included my configuration.h if you want to look at it.
    Configuration.h
  6. #106
    Engineer
    Jul 2014
    Location
    Eastern Colorado
    That might be the issue there. I have Z_SAFE_HOMING enabled. If I disable it, I have the problem of my Y axis moving while the Z raise before homing runs, which offsets the Y axis by the Z raise amount. It seems as though Marlin is unaware of the Y movement, as it doesn't change the Y current position number to reflect the move. I couldn't figure it out, so I just leave Z Safe Homing enabled to avoid it altogether.
  7. #107
    Super Moderator Roxy's Avatar
    Apr 2014
    Location
    Lone Star State
    I can confirm that the September 15th release of Marlin required extra Pre-Processor commands in Marlin_main.cpp in order to compile clean if the Sled stuff was not enabled. The code needed to be modified as follows:
    Code:
    #ifdef ENABLE_AUTO_BED_LEVELING
    #ifdef Z_PROBE_SLED
    // Method to dock/undock a sled designed by Charles Bell.
    // dock[in]     If true, move to MAX_X and engage the electromagnet
    // offset[in]   The additional distance to move to adjust docking location
    static void dock_sled(bool dock, int offset=0) {
     int z_loc;
     if (!((axis_known_position[X_AXIS]) && (axis_known_position[Y_AXIS]))) {
       LCD_MESSAGEPGM(MSG_POSITION_UNKNOWN);
       SERIAL_ECHO_START;
       SERIAL_ECHOLNPGM(MSG_POSITION_UNKNOWN);
       return;
     if (dock) {
       do_blocking_move_to(X_MAX_POS + SLED_DOCKING_OFFSET + offset,
                           current_position[Y_AXIS],
                           current_position[Z_AXIS]);
       // turn off magnet
       digitalWrite(SERVO0_PIN, LOW);
     } else {
       if (current_position[Z_AXIS] < (Z_RAISE_BEFORE_PROBING + 5))
         z_loc = Z_RAISE_BEFORE_PROBING;
       else
         z_loc = current_position[Z_AXIS];
                           Y_PROBE_OFFSET_FROM_EXTRUDER, z_loc);
       // turn on magnet
       digitalWrite(SERVO0_PIN, HIGH);
    #endif
    #endif
    void process_commands()
  8. #108
    Engineer
    Jul 2014
    Location
    Eastern Colorado
    That is how my marlin_main looks. Looking at the marlin_main in the ericzalm zip file, it seems the changes are to add a
    #ifdef ENABLE_AUTO_BED_LEVELING to the start of the code section, and its corresponding #endif at the end.
  9. #109
    Apr 2014
    Location
    Lone Star State
    Dacb, Right now the code says:
    if((f_probe_bed_position == b_probe_bed_position) || (r_probe_bed_position == l_probe_bed_position)) {
    SERIAL_ERROR_START;
    SERIAL_ERRORLNPGM(MSG_EMPTY_PLANE);
    Stop();
    return;
    Shouldn't this be changed to:
    if((f_probe_bed_position >= b_probe_bed_position) || (r_probe_bed_position <= l_probe_bed_position)) {
    SERIAL_ERROR_START;
    Stop();
    return;
    If these values are wrong, other code breaks, such as:
    int xGridSpacing = (r_probe_bed_position - l_probe_bed_position) / (n_points-1);
    int yGridSpacing = (b_probe_bed_position - f_probe_bed_position) / (n_points-1);
  10. #110
    Aug 2014
    Location
    Edmonds, WA
    Looks good to me. Have you tested this? If so, I'll make the change and publish it.
Tags for this Thread
