09-01-2014, 05:54 PM #1
- Sep 2014
Dual color shell with dual extruders possible?
I would like to know if there is a way to print and object like a vase with 2 shells and have the outer shell printed in translucent and the inner shell in a solid color? I have a dual extruder printer, and have been able to print in 2 colors using different .stl files for each color but could not figure out how to do different colored shells or if that's even possible.
Thanks
09-02-2014, 02:27 AM #2
A classical bi color process is to merge 2 STL into an AMF.
If you have the skils, you define the inner shell and outer shell as 2 different parts.
If you don't, try and do the following :
- original model is #1
- scale your vase to a smaller scale, try 95%. This is #2
- do a boolean operation to substract #2 from #1. This is #3
- Create an AMF by combining #2 and #3.
All these are doable in Meshmixer.
Just check in the end that you respect the basics : minimum thickness...Last edited by LambdaFF; 09-02-2014 at 02:33 AM.
09-02-2014, 06:31 PM #3
what printer do you have and what are you using to model the vase ?
09-03-2014, 07:47 AM #4
Yesterday, 01:26 PM in General 3D Printing Discussion
