Results 121 to 130 of 189
Thread: Show your MODS
01-16-2015, 01:26 PM #121
Here is my rear mounted spool holder! This created to lower the overall dimensions of the printer so it will fit in the smallest enclosure possible. Enjoy!
http://www.thingiverse.com/thing:638906
01-16-2015, 01:47 PM #122
That looks great!. I am sure you have tested it, how does the feeding compare to the regular spool holder?
01-16-2015, 01:49 PM #123
Thanks!
Ah forgot to mention that! It is great, so far has worked for me with no issues for two 1 hr prints. the spool rests on only the small cylinder extruding up from the spoke part in the center so there is almost no friction at all. No bearings necessary.Last edited by gmay3; 01-16-2015 at 01:50 PM. Reason: to give some thanks
01-16-2015, 01:52 PM #124
so the bolts and nuts needed are in addition to the ones coming from the LCD panel correct?
01-16-2015, 02:02 PM #125
Yes, all of them are spares from my kit although I'm not sure if others have them as well. At a worst case all the parts could be glued together where new screws were needed.
01-16-2015, 02:17 PM #126
Will be printing this out this weekend! I printed out the top bar for the wider spool holder but forgot to set the infil, and so while it printed pretty good, the inside is hollow and I wonder how well it will hold up. I like your design better.
01-17-2015, 11:55 AM #127
Hey Gmay3, I think you are missing the stl file of the piece that the post/spool holder mounts to.
Also the right side when I sliced it in Cura said it would take 15 minutes to print. When I got it loaded in pronterface, it looks to be missing the fram around the cut outs.Last edited by usarmyaircav; 01-17-2015 at 02:31 PM. Reason: typo, more info
01-18-2015, 05:18 PM #128
- Dec 2014
- Canada
- 498
Make a remix of some brackets including items from Clough42
for my fan shrouds for PLA
01-18-2015, 06:16 PM #129
- Nov 2014
- 522
gmay now i have to modify that somehow in sketchup to make it taller doe the large display knobs tend to hit the front of the frame.
01-18-2015, 06:16 PM #130
- Dec 2014
- Canada
- 498
link to this
http://www.thingiverse.com/thing:641891
