Results 1 to 8 of 8
Thread: Gaps, Need help
07-25-2014, 09:01 AM #1
- Jul 2014
- 6
Gaps, Need help
Hi everyone, I'm new and just get a 3D FUNSPACE 3D printer. Now I'm adjusting it, but there are gaps between some layers as below, can anyone tell me how to fix it? Thanks.
07-25-2014, 02:56 PM #2
- Jan 2014
- 462
Are you printing in ABS or PLA? If ABS, turn off your fan - it's probably causing your layers to curl and separate. ABS requires a warm and consistent temperature as it prints to prevent layers curling and separating.
07-25-2014, 09:24 PM #3
07-26-2014, 06:43 AM #4
- Jul 2014
- 6
Re-try today, I checked and adjusted the position of X-axis, now it's better, but there is still cracks in the middle, and back to normal for the top part. Only half side has this problem, the other side is ok. Also it looks like some dirty glue melt and drop outside of nozzle, almost drive me crazy.
Cracks and dirty glue
This side is fine
07-28-2014, 04:09 PM #5
- Jan 2014
- 462
Clean your print head - you might have some filament clinging to it that's burning and dragging in to the print.
Not sure what's causing the cracks, but have you calibrated your e-steps per mm or run through triffid hunter's calibration guide on the reprap wiki yet? that's always the first thing you should do when troubleshooting print problems.
08-04-2014, 07:23 AM #6
- Jun 2014
- 349
Filament cooked inside the nozzle? Might happen with pla running to hot.
08-04-2014, 07:37 AM #7
Do you have a cold draft coming across the print from the cracking side? Rotate your printer and see what you get.
08-06-2014, 01:37 AM #8
- Jul 2014
- 6
Thanks everyone~ I re-sealed the extruder and changed spring, and it works~
