    Student
    Mar 2020
    Ceciltucky
    Help Plz - Tronxy X5SA Pro - The need for speed!
    So I printed this calibration cube and it took 40 mins! It's only a 2cm cube that Cura estimated would take 18 mins.What's in the world is going on? Below is a pic of the recommended settings and the cube..
    What settings should I be looking at to change this? Or is it a problem that I need to change in the firmware?
    Hey! check you don't have any Post processing scripts run, before you slice you'll see an icon like the one below to the left of the "slice" button, i had this issue where it would change it to 15% speed at a certain layer, other than that check your movement speeds, although Cura should account for that in the time of the print. That's why the only thing i can think of is a post-processing error. Another thing you can try is if you have a speed adjustment on the printer screen, when it moves really slowly try turning it up to a different speed then back down to 100%, I've found this can also over ride the post processing options. Annotation 2020-04-08 120637.png
    Best of luck! hope this helps!
Tags for this Thread
