12-30-2017, 08:15 PM #1
- Jan 2016
- 326
How to buy linear shafts at Misumi USA store?
I wish to buy linear shafts at Misumi USA store but I don't know exactly what I need. They have "Bearing Steel" shafts at https://us.misumi-ec.com/vona2/detai...0042688%3a%3aa
I wish to build a larger version of my PowerSpec 3D Pro printer. I want to buy aluminum extrusions, linear shafts, and lead screws from this store. The build volume of my printer is about 9" x 6" x 6" and I would like larger version to be about 16" x 16" x 12". I may want to add parts for a CNC router similar to the one shown at http://www.microcenter.com/product/4...graver_Machine (the motor and bit). Any suggestions? I looked at OpenBuilds website but most of the machines don't have lists of parts that I need to buy in order to build them.
12-31-2017, 01:24 AM #2
- 887
What happens for you when you click on the Order link in the upper right corner? When I do, it presents me with a login and registration screen. As I am not desiring to purchase at this time, I've declined that option, but I suggest that completing the process would give you the ability to order the parts.
12-31-2017, 04:40 AM #3
- Jan 2016
- 326
If you look at the "Configure" tab, I'm confused by all of the options. Would be much easier buying a CR10 kit but many companies make CR10 kits and I don't know which one to buy. The largest CR10 kit has build volume of 500mm x 500mm x 500mm but CR10 kits have build platforms that move back and forth instead of up and down, are not enclosed, and I think they have Bowden feed instead of direct feed.
01-02-2018, 04:04 PM #4
- Jan 2016
- 326
Are there other places where I can buy
aluminum extrusions, linear shafts, and lead screws to build 3D printers or CNC routers? I'm afraid of buying stuff from Chinese companies like Aliexpress.
07-23-2018, 01:49 PM #5
- Jul 2018
- Canada
- 7
Check this store (located in Canada) :
https://voltatek.ca/13-mechanical-parts
Yesterday, 01:26 PM in General 3D Printing Discussion
