Results 1 to 10 of 12
11-13-2017, 08:04 PM #1
- Nov 2017
ProDesk3D - No software or Drivers, Help!
Hello all!
So basically, I've come into owning a ProDesk3D printer, and unfortunately the company who designed the printer has been bought out. I've already tried emailing the company and they are telling me that they do not have an archived copy of the software (they named ProModel). The previous owner has wiped the software long before ever giving the printer up to me. I've already asked reddit and have spent a little bit over an hour scouring google for an archived copy of this software and I legitimately can not find anything. Does anyone on this forum by chance know where i can find an archived copy of this software or have any sort of solutions? I would really rather not have this printer become a paperweight.
Thanks!
EDIT: Throwing this out there as an update for you guys who have replied. Thanks a ton for the help so far. I'll disassemble the printer when I get off work and see if I can get a pic for you guys. I'd rather not spend another $200 on duet for this thing, but if that's what it needs, I'd be willing to do it as a last resortLast edited by centerbrick; 11-14-2017 at 03:54 PM. Reason: stuff
11-14-2017, 06:02 AM #2
never heard of this before - just had a look and as far as I can see, they never got the software working properly and the whole project died without a trace in 2014.
It looks like it mixes 6 seperate filaments - so you might be able to use it as a single or dual colour printer. But anythig else will be a struggle.
If the people who built it couldn't make it work - not sure if anyone else will.
I'll have a look round for the software - but don't hold your breath.
I the meantime have you tried something like slic3r or cura - just to see if it will actually talk to the printer over a usb cable ?
Also contact the duet people: https://www.duet3d.com/
They've built a 6 way mixer printer and had it running at the tct this year - good folks, might be able to help.
But initially I'd concentrate on trying to get it to work as a standard dual print machine.
This is the initial filament feed setup:
Apparently it has 14 motors in total.
Wonder what board/s it uses ?Last edited by curious aardvark; 11-14-2017 at 06:07 AM.
11-14-2017, 07:42 AM #3
There are so few 3D Printer controller cards out there that will handle 6 extruders that you have few choices.
Choices include
1. You work programming your current controller, as curious said they never got the software working.
2. Convert to a Duet controller with up to 9 extruders
Duet WiFi and Duet Ethernet allow up to 9 extruders using their DueX5 expansion board.
I would think that this could be an alternative to your present controller. With many user forums you should have no problems installing software to make your ProDesk3D function correctly.
Yours could be the first functioning ProDesk3D duet combo.
Who knows maybe your controller is a Duet with a DueX5 expansion board.
Show photo of your controller maybe someone can identify.Last edited by Roberts_Clif; 11-14-2017 at 09:17 AM.
11-14-2017, 02:02 PM #4
11-14-2017, 04:40 PM #5
- Oakland, CA
- 935
If you already asked Crunchbase https://www.crunchbase.com/organization/botobjects you might try 3D Systems, which bought out the company (although I don't think it worked out for them).
11-14-2017, 05:50 PM #6
- Nov 2017
https://imgur.com/a/uXkzg
Here's that motherboard. Unfortunately, i've already tried out 3D Systems and they told me that they weren't even given the software by botobjects. Supposedly no one in their tech department has ever even seen the printer up close. I can't really tell what it is and seems like botobjects made their own board for the printer?
Thanks again guys for all of the help again.
11-15-2017, 12:54 AM #7
- Jul 2017
- 184
If you're willing to sacrifice the 6 extruder thing and just want it working, a $10 ramps/mega combo will probably work and be the cheapest option. I think the RADDS (ramps upgraded for 24V+ some other stuff) can handle your extruder requirements if you add the stepper expansion board and shouldn't be as expensive as a duet.
11-15-2017, 08:40 AM #8
- Nov 2017
So, using this setup, I'd be looking at the RAMPS, the Arduino Mega, and the stepper drivers all together? I'm not familiar with the RAMPS and how it interfaces with the Arduino. Is it a secondary processor? Do I still need to code the Arduino itself? Will it work with this printer setup (assuming I convert to a single filament)?
11-15-2017, 11:01 AM #9
wow it even has a fuse !
definitely custom job.
Never used ramps, but no reason you couldn't run it as a dual extruder, at the very least.
11-15-2017, 11:38 AM #10
- Nov 2017
How crazy do you think the coding will get for something like that? At the very least, I just want to get the machine to where it prints "something." Then down the line, I may think about replacing the motherboard with a duet and pull in more colors. I'm not exactly sure how the thing mixes the colors yet.
Yesterday, 01:26 PM in General 3D Printing Discussion
