  1. #1
    Technician
    Aug 2017
    Another X One problem
    Not to beat up on Qidi because I love the printer and run it every day, but I have had another issue. Grinding stuttering in the X-axis. Curious that if I reboot the machine it will quietly go through its startup routine, testing the limits and homing, until the printhead reaches the front of the y-axis (no limit switch in that direction) then the grinding starts. Once that starts it doesn't matter where the printhead is, it keeps grinding and stuttering. Reboot and repeat. I am thinking perhaps the x-axis stepper cable is bad so I ordered up 4 from Amazon yesterday, coming today. I guess we'll see...
  2. #2
    Technician
    Aug 2017
    Well, I just pulled the x-axis stepper motor cable and it tests OK. I am going to reassemble the printer and see if the issue persists and if so post up a video here and to Qidi support.
  3. #3
    Technologist
    Jul 2017
    You should merge your two threads. I just responded in the other, but you have completed that here.
