Thread: Another X One problem
10-20-2017, 07:07 AM #1
- Aug 2017
- 95
Not to beat up on Qidi because I love the printer and run it every day, but I have had another issue. Grinding stuttering in the X-axis. Curious that if I reboot the machine it will quietly go through its startup routine, testing the limits and homing, until the printhead reaches the front of the y-axis (no limit switch in that direction) then the grinding starts. Once that starts it doesn't matter where the printhead is, it keeps grinding and stuttering. Reboot and repeat. I am thinking perhaps the x-axis stepper cable is bad so I ordered up 4 from Amazon yesterday, coming today. I guess we'll see...
10-20-2017, 07:58 AM #2
- Aug 2017
- 95
Well, I just pulled the x-axis stepper motor cable and it tests OK. I am going to reassemble the printer and see if the issue persists and if so post up a video here and to Qidi support.
10-20-2017, 10:04 AM #3
- Jul 2017
- 193
You should merge your two threads. I just responded in the other, but you have completed that here.
Newbie Question
