Signup for our Free Webinar
  1. #1
    Ideamaker or Cura?
    I am trying out a print on Ideamaker ,have been using Cura.Which do you like better?
  2. #2
    Here's the first print l made on Ideamaker.It turned out pretty good,had some stringing.I had flow set to 96 ,does that seem the major problem?https://ibb.co/eDWkJw
  3. #3
    Technologist Roberts_Clif's Avatar
    Jun 2017
    Location
    Washington State, USA
    I have not made up my mind yet, Thou Cura is used the most.
    Each slicer has it's own features that I find come in handy so I have them All.
    Order in which I use slicers
    Cura 15.04.6 ; easiest to operate
    Cura 2.7 ; Different layer Height in single Model
    Meshmixer ; Manual placing of supports
    Slic3r
    ..........Ect
  4. #4
    Jul 2014
    never heard of ideamaker, have to have a look.
    Glad it's not just me, I don't think the latest cura is particularly user friendly.
  5. #5
    im aggree i think most people or 3d pritner are using cura as well right?
  6. #6
    Jun 2017
    Location
    I did some testing using idealMaker, was testing for another forum user model was a tube with 8 support ears.
    Holder_Lower.stl
    When sliced the ears are detached from the model, could not determine how to slice with idealMaker so the ears were connected.
    idealMaker Slice
    Slicing works in Cura. Would still like to determine what setting would be needed in IdealMaker to correctly slice the model.
    Cura 15.04.6 Slice
