Signup for our Free Webinar
Results 1 to 5 of 5
Thread: Lube bearings?
    Lube bearings?
    I have some silicone oil and lithium grease ,which should I use if any on the bearings and threaded rods?
    Staff Engineer Davo's Avatar
    Nov 2013
    Atlanta, GA
    What does the bearing manufacturer recommend? Mine recommends a drop of WD-40 every 20,000 km.
    Engineer-in-Training
    Aug 2015
    Quote Originally Posted by Davo View Post
    Really? WD-40 is not a lubricant at all--in fact it's the opposite in that it will break down and remove whatever lubricant is present.
    WD-40 was designed as a water repellent and rust inhibitor.
    Technologist Roberts_Clif's Avatar
    Jun 2017
    Washington State, USA
    Quote Originally Posted by mcc1961 View Post
    Silicone Oil, lithium grease is to thick and inhibits smooth rod bearings from making micromillimeter movements.
    Nov 2013
    Atlanta, GA
    Good catch. Let me clarify. Our bearing manufacturers recommend to check to see if lubrication is needed every 20,000 km. My CTO recommends WD-40 for this purpose.
    Quote Originally Posted by djprinter View Post
