  1. #1
    Creality CR 10. print from SD Card or?
    I havnt been able to get a print started. The machine only seems to have an ability to print from an SD Card. Even though a USB Cable was provided and has a port on the control box.
    I downloaded a simple model from thingiverse to run as a test. Sliced it with Cura. Saved the g-code file to the SD. Inserted the SD to the control box, navigated to "print from SD".... but I don't really get past this. The options are refresh and something else i can't remember. But neither do much.
    Any help would greatly be appreciated.
  2. #2
    Technologist Roberts_Clif's Avatar
    Jun 2017
    Location
    Washington State, USA
    3D Printer SD Cards are formatted in Fat, so what size is your SD card.
    Your 3D Printer may not recognize the SD Card if it is too large
  3. #3
    Jul 2014
    or if the card came with the printer it just might be faulty.
    Best sizes for 3d printers are 4-8 gb sd cards.
    They're dirt cheap and will hold hundreds of prints.
  4. #4
    Jun 2017
    Location
    Quote Originally Posted by Sen2two View Post
    If you need help setting up Cura simply ask
    Posting a picture of the error you get. will help you solve your problem.
