Results 1 to 7 of 7
07-25-2017, 01:27 PM #1
- Jul 2017
Level Build Plate Option Missing in Firmware 2.6.0
I can not find the level build plate option on my makerbot replicator + since i installed Firmware 2.6.0. Anybody else having this issue??
08-02-2017, 07:02 AM #2
- Aug 2015
- Wisconsin USA
- 27
It's still there on my 5th gen. I looked at the release notes and it says the moved and re-titled it on the Rep+, but they don't say where they moved it or re-titled it too...
Replicator+: Moved and retitled the "Level Build Plate" script
https://support.makerbot.com/learn/m...se-notes_12252
12-09-2017, 12:26 PM #3
- Dec 2017
I'm having this same issue, any resolutions tot his problem ?????
12-14-2017, 03:42 PM #4
- Dec 2017
I contacted Makerbot and they said they decided to remove that feature. At the moment I am attempting to go backward to Firmware 2.5, but I'm not sure if it will work. Maybe I'll reset to factory settings and then update to 2.5.
Update: I got the bed leveling wizard back by reverse updating the firmware to version 2.5...Last edited by Masher; 12-15-2017 at 01:27 PM.
12-14-2017, 10:18 PM #5
My suggestion is to bring up Marlin. https://github.com/MarlinFirmware/Ma...e/bugfix-1.1.x
05-30-2018, 03:02 PM #6
- May 2018
- 9
2.6 uodate has the bed level feature in it, as it levels the bed before each print and uses an algorithm to compensate for it
07-25-2018, 09:31 AM #7
- Jul 2018
- Canada
- 7
In my opinion, removing options from the firmware is a bad idea... I don't like makerbot anymore.
Change your firmware for Marlin or Sailfish.
https://voltatek.ca
Which 3d printer for small...
