Results 1 to 8 of 8
    Exclamation Print head motor does not extrude filament
    Hi all,
    The motor in my Hyrel 3D printer is making noise (working), and the extruder is slowly rotating. However, no material is flowing from the print head. Can anyone help with this? Thanks. It is also a Vol 25 Pro Head.
    I don't think it's a plugged nozzle because it's our first time using the print heads (we've tried both the hot and cold) and we used a thinner mixture (water and flour) that can still flow. It's frustrating because it is "printing" but just nothing comes out.
    Also, when I connect the SDS (cold print head), the printer picks it up as another one, so then it doesn't push down on the syringe at all.
    contact davo - or phone hyrel up.
    Pretty sure they'll be very helpful :-)
    Staff Engineer Davo's Avatar
    Nov 2013
    Atlanta, GA
    Hi, tam105.
    First, you need to displace the air in the nozzle of the VOL-25 head before material will come out. This may take a minute or two, even at 2000 ppm, because of the gear reduction and the threading on the screw. Also, ensure that the 3/8" socket connector on the head is seated on the square area on the top of the material reservoir, and that the reservoir is mounted tightly enough that it doesn't spin in the head.
    If the shaft (but not the entire tube) is spinning, but material is still not coming out, give me a call. The number is printed on the back of the printer, and on our website. http://hyrel3d.com
    Davo
    Nov 2013
    Atlanta, GA
    Any luck yet? Give me a call if you need help.
    Nov 2013
    Atlanta, GA
    Really, just call or email me.
  8. #8
    Nov 2013
    Atlanta, GA
    Well, we're here when you need us.
Tags for this Thread
