Results 51 to 60 of 109
Thread: What printer around 600€
07-21-2017, 05:33 PM #51
- Jul 2017
- 59
Hello guys we finally received the x-one2, assembled it all but at the time of printing, the printed doesn't recognize any gcode or stl files other than qidi's own. For example we tried to print https://www.thingiverse.com/thing:468651 this keycap here. but doesn't recognize any of the extensions and we tried qidi's own slicer and cura, we used the sd card, not even through the cable. Any idea?
07-21-2017, 06:07 PM #52
- May 2016
- Annapolis, MD
- 523
I've got the QiDi Tech 1, no personal hands-on time with an X-one. Tech 1 uses X3G, not GCODE. There is usually a X3G converter application (like thingiverse GPX https://www.thingiverse.com/thing:81425 ) or a selection in the slicer.
07-21-2017, 08:06 PM #53
- Jul 2017
- 59
We've been printing successfully few keychain through usb, it prints pretty good, far better than the davinci by far, but we still haven't figured out how to print via sd card, but then again we only tried gcode and stl, and it seems not to be working, anyway my X-one is closed, it came with 3 plexiglass panels to mount, and we actually realized it's the X-one 2, so probably a refresh, or revision, but seriously so far so good, for ~430€ it does a better job compared to a ~630€ printer.
http://i.imgur.com/DaTcriN.jpg
07-21-2017, 09:08 PM #54
- Jul 2017
- 59
07-21-2017, 09:20 PM #55
- May 2016
- Annapolis, MD
- 523
Please take and publish more pictures. This is the first and only info on this new version from QiDi that I've been able to find.
07-21-2017, 09:26 PM #56
- Jul 2017
- 59
I surely will, but it's 4:30 am here so i'll soon go to bed i'll probably do it tomorrow.
Anyway the x3g converter looks a bit complicated to set, even because there's no accurate instructions, is there something easier to set you know about? Anyway i'll probably do everything tomorrow.
07-21-2017, 09:33 PM #57
- May 2016
- Annapolis, MD
- 523
Sorry, I use Simplify 3D. It performs the X3G conversion by invoking GPX. No idea what's going on under the covers.
07-22-2017, 08:29 AM #58
- Jul 2017
- 59
07-22-2017, 09:07 AM #59
- Jul 2017
- 59
07-22-2017, 09:33 AM #60
- Jul 2017
- 59
I'll try that and let you know if it works, at the moment i'm printing a little bowl, it's coming out pretty nice, but i set faster settings and the larger part is not that accurate, it has few flaws, but it's ok anyway. As soon i finish the printing, i'll install and try flashprint and will let you know
04-22-2024, 01:26 PM in General 3D Printing Discussion
