Thread: NEW M3D Promega
06-26-2017, 01:19 PM #1
- Feb 2017
- 3
NEW M3D Promega
Has anyone looked into the newly releasing M3D Promega? It's available right now for less than $1200 and will retail for $3500. Thoughts?
http://sites.printm3d.com/promega.html
M3D Promega technical specifications:
- Build size: 15.3 in / 38.8 cm build (cube - 15.3x15.3x15.3)
- Printer Dimension: 20x20x22in / 50.8×50.8×55.8cm (cube)
- Weight: 25 lbs / 11.3 kg
- XY – 0.6 micron microstep resolution
- Z – 50-750 micron layer resolution (dependant on nozzle size)
- Up to 300mm/s motion (typical high quality printing at 45-60mm/s)
- Heats Up to 300°C (420°C with thermocouple add on)
- Connectivity: Ethernet with built-in Webhost
- USB host
- SD Card (for stand-alone mode)
- Print from any web-enabled device
- Runs off Gcode, sliced from STL and other 3D model file types
- Compatible with all 1.75mm filaments (not included with printer)
- Open electronics and hardware
- Open firmware (Smoothie or Reprap firmware)
- Open software (3rd Party Host Controllers)
(from: https://3dprintingindustry.com/news/...ations-116093/)Last edited by MattSmith; 06-26-2017 at 01:28 PM. Reason: Pricing and Specs
06-26-2017, 01:41 PM #2
looks good - but if it's 'overengineered' why is it only using nema 14 motors ?
Anyone ever bought a micro+ ?
The original micros had a fair few issues and wouldn't encourage me to buy from the company. Just wondered if the + sorted most of the problems out.
At $3500 with a lot of the cool stuff being extra, it's not competitively priced.
Which 3d printer for small...
