Flash Forge Inventor
    Zortrax G-Code conversion and ZCode patching
    Just in case that this isn't known yet, some links to my tools:
    RaftAway (raft removal, extrusion/speed/retraction patching)
    https://www.dropbox.com/sh/vbsev07y2...d-WMUM9Ba?dl=0
    g2z (G-Code to Z-Code conversion)
    https://www.dropbox.com/sh/cgt3evjon...gKgIB5kha?dl=0
    ZTool (all the features of RaftAway and g2z plus preview, support removal, fan profile display/export/import, patching of temperatures/offset etc.)
    https://www.dropbox.com/sh/91jdv24ta...o0cKEkwOa?dl=0
    Profiles for G-Code conversion (basic, mainly meant as starting point)
    https://www.dropbox.com/sh/tmv5imtvw...qyVntXdTa?dl=0
    All the tools are in Java, should run on any platform that support the Java Runtime (Windows, MacOS, Linux).
    There's always a short manual in rich text format (RTF) included as well as Icons for Windows (*.ico) and MacOS (*.icns).
    Have fun.
    Updated g2z to 1.0.4 and ZTool to 1.0.5
    Changes:
    Added support for Z-PLA Pro, Z-ASA Pro and firmware 1.1.1.
    Reduced minimum extruder temperature to 160C
    To continue my monologue:
    ZTool:
    1.0.6
    Fixed issue with empty retraction commands created with newer versions of Z-Suite.
    Improved ZCode support for Inventure.
    1.0.7
    Added option to increase distance between raft and first model layer.
    Separate speed setting for 1st model layer.
    Fixed: export dialog didn't keep/display setting from previous export.
    Fixed: export dialog didn't offer PLA and ASA profiles and therefore changed profile name to ABS.
    g2z
    1.0.5
    Removed the <=10 layers check and improved error/warning messages.
