Results 381 to 390 of 474
10-24-2017, 05:32 PM #381
- Jul 2017
- 193
yeah, I agree with the 4 wheels. That was one of the reasons I picked HE3D over other delta's ( Not to mention yours and #40fan's glowing comments and upgrades. )
10-25-2017, 10:01 AM #382
I'm beginning to hate stuff without manuals.
So the new board seems fine, talks to the computer to the extent I can access the card on the board through the computer.
Firmware seems to works and I can talk to it through repetier host.
But the fracking touch screen does not come on. The one thing I had absolutely no issues with on the board that i couldn't get firmware on.
There are two jumpers, I have tried both in both positions. No difference. I think one changes steps from 16 to 32. The other is labelled 3v3 and 5v and doesn't seem to make any difference whichever it is in.
AAAARRRGGGHHHHHH !!!!
I will try the cheapo lcd now.
Well that powers up - but doesn't display anything and through the little speaker it sounds like a ghost screaming.
Is it me or what ?
Oh yeah the cheapo lcd doesn't work in the other board either.
See if I can find any info. Autowhiz he just plugs the screen into the board and it works. I wish, lol
So I had a thought (it occasionally happens) maybe becasue the sbase is a bit bigger and has more oomph, the screen will only work when the boards is hooked up to 12v.
I was right. Fired up right away :-)
So that's good.
Also the smoothieware comes with a really good manual that explains what you measure and how to get the arm lengths and spacing settings correct.
With pictures no less !
So that's all good :-)
Cheapo lcd screen still just screams. Figure that's doa and write it off.
When i take alexa apart for the mosfet I'll try it on her. But pretty sure it's a goner.
Board works, that's what counts :-)
So I better get on and build the rest !
oh yeah heres' the two boards side by side (kinda)
10-27-2017, 10:13 AM #383
Ordered some 500mm carbon fibre shafts. Only need 400's but you can buy 1metre, 500mm 300mm or 200 mm. Got 10 so I can practice cutting them.
Think I've got a really height tpi belt for the bandsaw that I've never used - that should do the job.
They'll have inserts to hold the magnets, so I can make the length adjustable to a small degree anyway.
One issue I will have is measuring the length accurately.
The digital calipers only go to 150mm, my steel rule goes to 300. I need a something that both goes to 500mm and is accurate on tenths of a mm.
11-01-2017, 06:55 AM #384
shafts arrived.
Look good, got 10 so i can aford to breaka couple lol. Just need to work out how long.
I figure 400mm and adjust if necessary with the magnet holder.
11-02-2017, 04:25 PM #385
- Oct 2017
- 19
I apologise for not reading all 39 pages here (stopped at around 15 ), but could you tell me if this printer works with Octopi? Thanks!
11-02-2017, 10:03 PM #386
- Jul 2017
- 193
11-03-2017, 04:02 AM #387
- Oct 2017
- 19
Ordered one
11-03-2017, 06:37 AM #388
actually after the middle of the thread it kind of morphs into my building a very large delta competely from scratch. So I reckon you've probably read most of the he3d k200 relevant stuff :-)
Standard gcode and usb connection - so no reason for it not to work with any of the external print managers :-)
11-03-2017, 04:24 PM #389
Got the magnetic holder shaft connecters done.
Now here's the thing. I made these so the cupped magnets would simply clip into the holder. I'm reproducing my plastic connectors to a really precise set of measurements, but the chinese magnet makers - not so much, lol
First one - the one I measured - clips really clean and tight, it's not coming out short of breaking the holder. I know this as I had to break the test print to get the magnet out.
Second magnet, is slightly smaller and tilts ever so slightly and will need a dab of glue as it has the potential to come out over time. The ledge holding the magnets in is only 0.25 mm wide, which with the correct sized magnet - is all it needs to be :-)
Camera appears to be elsewhere, I'll take some pics when I find it. But the balls go in and can hang at 180 degrees, which is probably 10 degrees more than they'll ever need to :-)
Currently printing some black shaft ends to match the shafts.
11-10-2017, 05:00 PM #390
- Oct 2017
- 19
How come there are a lot of posts no longer visible in this thread? When reading through it's like one big monologue because the posts of other users seem to have disappeared?
