Results 1 to 5 of 5
05-07-2017, 04:48 PM #1
- May 2017
PEI bed has little to no adhesion
It looks like I am one of the few who is having very bad luck with my newPEI sheet. I cannot get PLA or ABS to stick very well. I have tried the following:
Cleaned with IPA
Cleaned with Acetone
Cleaned with Acetone then IPA
Tried hair spray
Tried PVA glue stick
Tried Elmer spray adhesive
lowered and raised Z offset (inductive sensor auto level)
Increased bed temp 50-80 PLA and 70-100 ABS
Increased and decreased extrusion temperatures
I have abraded the surface with 280 grit sand paper
I have to note that i used Kerosene to remove the Elmer spray adhesive. IPA and Acetone would not touch the stuff.
I will admit I have been able to finish some prints with PLA but the corners are pealing up. I just can't believe blue painters tape is so much easier to use that this.
Its a bummer, but I actually put blue painters tape on top and the only adhesion issue was the tap to the bed. Filaments stuck great to tape.
05-08-2017, 06:24 AM #2
yeah I tried pei tape for a short while - wasn't impressed.
I can recommend printbite. After 18 months of trying everything else I've been using printbite for over a year now, with no problems.
What printer do you have ? And what are the conditions of the room it's in ? temp and humidity primarily.
Enviromental conditions can have a disproportionate effect.
My biggest issue with blue tape is that it can pull off (although if you apply it to a hot bed, it's better) and you often get blue marks on the base of the prints.
Printbite isn't miraculous, but it's better by a long way than anything else I've tested in the last 3 years.
05-15-2017, 05:37 PM #3
I've been using GekoTek with pretty consistent results. Some prints still need a brim, but its a lot better than when I tried PEI.
05-16-2017, 05:56 AM #4
never got round to the gekkotek - is it smooth or one of the textured surfaces ?
05-16-2017, 09:14 AM #5
It's very slightly textured, but I think smooth is a better overall description. I can vouch for both the RT and HT plates, but the RT plate does seem to work a little better than the HT, at least for PLA. Honestly I think the biggest advantage it has is that you can just flex the metal plate and the print pops right off.
04-22-2024, 01:26 PM in General 3D Printing Discussion
