Thread: Printing Problem
04-11-2017, 03:51 PM #1
- Apr 2016
- 8
Printing Problem
I have a new Creality CR-10 3D printer, and I have been having difficulty with the 3d prints. Here is a picture of the first layer for several parts being printed at one time. IMG_20170411_160434972 (1).jpgThe parts are printed with a brim using black PLA. Essentially what is happening is that the first layer appears to be thicker in some places than in others. I am a bit puzzled as to why this is happening since I was very careful about leveling, and since the darker regions aren't always in the same places. I am not sure why this is happening. Can anybody advise me as to what I am doing wrong. It is being printed on glass. I used a mixture of elmer's glue and water painted onto the surface and dried at 60 degrees C. I have been using Cura to slice with the following settings.
Layer Height 0.1 mm
Initial Layer Height 0.1 mm
Wall Thickness 1 mm
Top/Bottom Thickness 1 mm
Infill Density 100%
Printing Temperature 196°C
Diameter 1.75 mm
Flow 90%
Enable Retraction
Print Speed 40 mm/s
Infill Speed 40 mm/s
Outer Wall Speed 25 mm/s
Inner Wall Speed 25 mm/s
Travel Speed 40 mm/s
Enable Cooling
Minimum Layer Time 5 s
Brim Width 8 mm
Print Sequence All At OnceLast edited by djf435; 04-11-2017 at 04:00 PM.
04-12-2017, 08:09 AM #2
could just be printing too cool.
try printing at 210c
And pic too blurry to see any detail. Move the camera further away so it can focus.
05-01-2017, 02:13 AM #3
Or your nozzle sits too close to the printbed causing pressure buildups inside so the flow rate is very uneven.
For PLA my flowrate setting is 103-106%.
QIDI Slicer "Plater" is...
