  1. #1
    Left extruder will not print
    Hi,
    I have had my printer for a couple of weeks. Yesterday I finally found the Sailfish manual and worked through 5.2 Dual Extruder Calibration.
    Now I can print perfectly with the right extruder, but when I print with the left one, everything heats up as normal and then the print head goes to the zero position (bottom right) and stops. Nothing else happens.
    I have reset all the settings in Simplify3d and I have done UTILITIES/ RESTORE SETTINGS on the printer. But nothing seems to fix it.
    I hope this is not a newbie problem, I did search for a solution but I can not find anything and mainly I do not want to break things even more
    Any help appreciated!
    G.
  2. #2
    Resolved
    Resolved - Stupidly I was not using the Sailfish version of ReplicatorG, so the settings were written incorrectly. DOH.
  3. #3
    Quote Originally Posted by garjones View Post
    ReplicatorG? You're using RepG to slice? Why? Its outdated and slow. Try Flashprint.
  4. #4
    No, not to slice - just to mess around with firmware settings. I use Simplify3D to slice
