Thread: Print problem
  1. #1
    Print problem
    See attached picture. My Hictop printer has been printing great without issue, but recently started doing this. This is a 10x10x20mm test column. As you can see it is not smooth. Any ideas on what is causing this? I have y & x axis belts with no improvement.
  2. #2
    Engineer ralphzoontjens's Avatar
    Nov 2013
    Location
    Tilburg, the Netherlands
    Follow ralphzoontjens On Twitter Add ralphzoontjens on Facebook Add ralphzoontjens on Shapeways Add ralphzoontjens on Thingiverse
    Can you post the picture again?
  3. #3
    I have tried. Does not seem to be working.
  4. #4
    Nov 2013
    Location
    Uploading a smaller picture usually works better.
    It is likely to do with your flow and temperature settings.
    But it can also be that a component of your print bed assembly or end stop mounts are loose.
  5. #5
