Results 1 to 7 of 7
04-07-2017, 08:19 AM #1
- Apr 2017
- 7
Monoprice Maker V2 printing issue?
I've had my MM v2 for a couple days, had success with the gcodes on the flash drive but running into issues when printing items outside of that. For some reason one end of the print does not stay adhered to the plate. I'm novice with 3d printing but am an engineer and a quick learner. I've played with adjusting the settings in Cura to slow down the printing (solved issues of nothing sticking at the beginning) but now part way through one side pops up.
Is this a known issue with this printer and/or is this possible to fix by adjusting the temperature of the plate or another setting? Or is this possibly a starting base issue?
04-07-2017, 02:02 PM #2
your bed needs calibrating.
It can be a fine line to get it perfectly even - but you need to :-)
An awful lot of problems can be traced back to a badly calibrated bed. your problem is definitely one of them.
04-07-2017, 02:16 PM #3
- Apr 2017
- 7
04-08-2017, 11:42 AM #4
yep. is it larger prints that are not sticking ?
Calibration can be a real bastard. I always heat both the bed and the nozzle - some tell you just to heat the bed.
each to their own.
I like to heat both and use 90gsm paper quite tight between the nozzle and bed.
All i can say is it works for me.
04-08-2017, 11:58 AM #5
- Apr 2017
- 7
04-08-2017, 12:00 PM #6
- Apr 2017
- 7
I did a 14 hour print yesterday and while 1 side did pop up within the first hour it finished the print out just fine.
05-31-2017, 07:10 AM #7
- May 2017
- 5
I have that same printer, what material are you using and what is your print bed temperature set at? I have had good results at 55 degrees for the print bed with PLA.
