  1. #1
    printer printing onto the air instead of the plate
    I have a Monoprice MP Select Mini 3D Printer, and I recently got in my filament. I am trying to print a test job, but the printer is not printing onto the plate. it is instead printing into the air. If I make the printer nozzle go lower it resents to a higher position before I print. Please someone help me.
  2. #2
    Engineer Marm's Avatar
    Sep 2014
    Add Marm on Thingiverse
    Recalibrate or relevel the bed. The bed is most likely in a different position than where the printer thinks it is. If not, check your gcode for some instruction causing it to lift. What slicer are you using? There my be a setting wrong there.
  3. #3
    Im using slic3r. I may know what it is. is there A way I can post a video to the thread?
  4. #4
    Actually I believe I have it fixed but it may only be temperary. but I am having a new problem. I am printing but it isnt sticking to the board. only some of it sticks
  5. #5
    Technician
    Mar 2015
    Location
    Fenton, MI
    I had slic3r raising my nozzle about 2 mm before every print. I switched to Matter Control. Better interface and consistent prints.
  6. #6
    What setting raises the nozzel in splicer? And i may try that as well
  7. #7
    Sep 2014
    Quote Originally Posted by theamanjadon View Post
    Try glue stick.
    I'm going to add that to my signature.
    What are you using for adhesive?
Tags for this Thread
