Results 11 to 12 of 12
02-16-2017, 06:23 AM #11
For something that size I'd probably use 0.2mm layer height not 0.3.
Also do you have a print area cooling fan ?
Good idea to use one - particularly with very small items.
And what filament are you actually using ?
Extruder Temps would suggest abs while bed temps would suggest pla, although too cool. (should be 60 for pla).
So that's a little confusing. 235 is way too hot for extruding pla and too cool for pet-g and abs. While bed temp is way too cool for abs and petg and slightly too cool for pla.
Also what surface are you printing on ?Last edited by curious aardvark; 02-16-2017 at 06:31 AM.
02-16-2017, 10:10 AM #12
- Feb 2017
- 11
He's printing with TPE type filament its in the title.
The .3 is not the layer height its the initial layer height in cura
235 is fine for the tpe temps
