02-04-2017, 11:06 PM #1
- Feb 2017
Issues leveling Flashforge Creator Pro
Hi all,
I havent' used my flashforge creator pro in about 8 months (although I've kept it clean). Having come back to it, it will no longer level. The right side of the print bed seems to be fine and adjustable (I can get the right distance from the extruder to the print bed) but both the left and the front of the bed will not adjust.
I've tightened the front and left screws to their maximum - I can physically no longer tighten them, but the extruders still drag along the bed when leveling (to the point of ripping the paper Im using to adjust). They both will loosen fine but this just pushes the bed further towards the extruder.
Any ideas? Has the printer bed warped due to lack of use? Should I warm up the bed and see if its more flexible?
Any ideas would be appreciated
02-06-2017, 11:09 AM #2
No bed is most likely not warped.
You might have to raise the nozzle/hot end a bit to get more adjustment range.
QIDI Slicer "Plater" is...
