Results 1 to 10 of 10
Thread: Bad 3D Benchy
    Bad 3D Benchy
    My 3D Benchy test print did not come out great. I have a printrbot simple metal.
    Do you have any recommendations on how I can make my prints better? Thank you!
    Engineer-in-Training
    Aug 2015
    Please post a list of the settings settings you used, and what printer,
    also don't print in transparent materials, you cant clearly see all the defects
    Technologist 3dex ltd's Avatar
    Dec 2015
    United Kingdom
    Follow 3dex ltd On Twitter Add 3dex ltd on Facebook
    As above, please post a link to your slicer setting and that will really help.
    However, a few points:
    It seems that your Benchy is fairly small and this may affect the quality of the model. (try printing bigger if possible)
    Also, your layer height (resolution) seems quite high. I would suggest a layer height of 0.1mm. Or if you want a really detailed model perhaps try 0.05mm layer height.
    I can also see your infill lines showing through. Although this is common and probably not something that is very bad, you can fix this by having a thicker wall (try 0.8mm) or asking your slicer to print the wall before the infill.
    I hope some of these above points help. With a picture of your settings I might be able to be of more help.
    Regards,
    3DEX - Great Filament
    Here are some pictures.
    I can get screenshots of the slicer settings in a minute.
    Here are the Cura settings.
    I am using the Printrbot Simple Metal with an X axis upgrade.
    Aug 2015
    your pics of the Cura settings are too small toe read
    the other pictures looks like the temp is a bit too high, and the has a lot of ringing,you could adjust the jerk settings so the are slower, and try a lower and slower temp
    Not entirely sure what you are expecting - but those prints are quite good.
    And yep, even i can't read the settings even if I get real close to the monitor :-)
  8. #8
    Apr 2015
    Northern Ohio
    Quote Originally Posted by This View Post
    I agree here it looks like you are running a bit hot. Back it down a bit and repost your setting and we can help you clean those prints up a bit.
  9. #9
    Apr 2015
    Northern Ohio
    shakes head...
  10. #10
    Student
    Feb 2017
    Birmingham
    Add seo-birmingham on Facebook Add seo-birmingham on Google+
    Quote Originally Posted by JasonLavender View Post
    Thank you!
