01-20-2017, 09:03 AM #1
- Aug 2016
- 25
First Print Pegasus 12 X axis issue
After a few months of required attn to some work around my house I finally got around to finishing my first build.
Printed this cube with Hatchbox PLA at 200 ext and 70 bed. .2 layer height. Using S3d and a profile I got from this forum.
As you can see the left side of the X axis is all over the place, the bottom is facing you and did not fill on the left side. My initial thought was loose belt but I could barely get that X belt on because I cut it too short.
Ideas?
01-20-2017, 03:29 PM #2
- Dec 2016
Have you properly adjusted all your eccentric spacers on your rollers and adjusted your rollers so they glide along the rails smoothly without bouncing around?
01-21-2017, 04:55 AM #3
- Aug 2016
- 25
Thanks hopster, I had one wheel that was not contacting the rail as well as the other 3 and there was a tiny bit of slop in the carriage. Tightened those up and am trying this again.
01-21-2017, 08:48 AM #4
- Aug 2016
- 25
Best benchy I have ever made in PLA and I don't even have a part cooling fan.
