Thread: resoldering wires on the fans?
09-29-2016, 10:10 AM #1
- Sep 2016
- 2
Hi there
please could I ask:
when I repaired a blocked extruder on the Replicator 2
the wires attached to the fans tore off from the solder points : if I resolder does it matter which coloured wire (red, black) goes to which point on the fan?
ie will it short the control board if I get them the wrong way round?
Many thanks
Simon
09-29-2016, 11:11 AM #2
The fan will run backwards.
09-29-2016, 11:26 AM #3
I'm not sure what fans MakerBot is using, but a fan that runs backwards would be unusual. All the small DC fans I've ever seen will simply just not run if the power leads are reversed.
Birdy100, regardless, yes it does make a difference in how the fan will work. But a typical fan won't damage the electronics if the power leads to it are reversed.
09-29-2016, 11:30 AM #4
- Sep 2016
- 2
Thanks for your answers guys , I will get on with the soldering
best wishes
Simon
