Results 11 to 16 of 16
09-15-2016, 09:39 AM #11
- Jun 2016
- Oklahoma
- 904
Yea, I've done it sort of like the video. When you look at the spring one end is hooked at the end of the loop so it will stay on the belt and the other is straight like in the video so it can slide onto the belt. It was a pain to do in close quarters with needle nose pliers. I think if you could compress it so the two ends are up and the coil part is lower then it could slide onto the belt and when you let go the ends would go out towards the sides and the coil part would move up. I'll have to try and if it works take some pics.
09-15-2016, 09:43 AM #12
- Jun 2016
- Oklahoma
- 904
Here is just what I did before on another machine. It's not so easy when it's up in the machine and you have no room or visibility!!
09-15-2016, 10:02 AM #13
09-15-2016, 10:46 AM #14
- Jun 2016
- Oklahoma
- 904
09-16-2016, 10:46 AM #15
Generally to realign the gantry with fixed pulleys, you have to kind of grip it and rip it. Essentially skip the belts into position.
09-16-2016, 02:30 PM #16
- Jun 2016
- Oklahoma
- 904
Got the gantry re-aligned. Undid the belt on one side and got it straightened out then got the belt back on. A bit of a pain but it worked and we are up and running.
QIDI Slicer "Plater" is...
