Results 1 to 8 of 8
Thread: Glue two ABS pieces
05-05-2016, 11:27 AM #1
- May 2016
Glue two ABS pieces
Hi all!
Sometime ago, I printed two ABS pieces with a 3d printer. Now I would like to glue them but I don't want the intersection to be visible.
Is there any glue or method in order to do it?
Thank you!!
Mikel.
05-05-2016, 03:57 PM #2
- Burnley, UK
- 1,662
Acetone or MEK. Acetone is slightly less nasty
05-05-2016, 04:00 PM #3
- Oakland, CA
- 935
05-05-2016, 04:32 PM #4
- Burnley, UK
- 1,662
05-06-2016, 12:00 AM #5
Acetone works great to cold-weld two pieces of ABS but there will be a witness. Sanding will be required.
05-06-2016, 06:20 AM #6
- May 2016
But using Acetone or MEK would the intersection be deleted? Woudl it be like a single piece?
05-06-2016, 07:06 AM #7
- Burnley, UK
- 1,662
If you did it right then it would. If you are not skilful at it then it will get narrower than it was.
05-11-2016, 12:36 PM #8
- Aug 2015
- 256
You can dissolve abs into acetone to thicken it to whatever consistency you want.
