Results 1 to 9 of 9
Thread: Same Question as usual!
04-29-2016, 07:04 AM #1
- Jan 2015
- 12
Guys Not new to 3D printing, but never had one! hhehehe
My Option will be aliexpress for two reasons, price and price!
So here are my options so far
- Folger Tech 2020 ( Link) - This will be shipped from US!
- Ultimaker 2 like (link) It is also a DIY, however I liked the reviews and ammount of buyers, it looks to be a nice printer
- Prusa i3 based (link) - This is the cheaper one, but I still believe it is a good shot!
Bottom line, I'm looking for something that I will be able to print my ideias for simple to larger stuff and also sometimes try ultra resolution ( 0.05)
Thanks
04-29-2016, 07:47 AM #2
ignore the last link. acrylic versus metal frame - no contest go metal frame every time.
I'd go for the ultimaker clone.
Larger build volume, yeah it probably 3mm filament anda bowden setup - but, if they've copied ultimaker it should work well.
And that's a really nice build volume. Also a full frame not just a gantry.
04-29-2016, 08:00 AM #3
- Jan 2015
- 12
These are the high level specifications
- Color Print Speed:300mm/s
- Model Number:CL-260
- Structure Material:Aluminum alloy
- XY Axis Positioning Accuracy:0.012mm
- Z Axis Positioning Accuracy:0.004mm
- Max Paper Size:220*220*260mm
- Extruder diameter:0.4mm
- Filament Diameter:1.75mm
- File Format:STL,G-Code
- Brand Name:langwei
04-29-2016, 10:59 AM #4
yes, i looked at the links :-)
Forget 300mm/s - probably 100 - 200 maybe. And the higer speeds are always at high resolution - so very thin layers.
But still good.
Just remember that claimed print speeds are just that: 'claimed' :-)
04-29-2016, 11:25 AM #5
- Jan 2015
- 12
Interesting. Now my only question regarding this printer is:
Will I be able to upgrade for a E3Dv6 for example? (at least original one) ? I noticed that I will need to buy the heated bed separated or choose the bigger size which already has it included for almost 100 dollars more.
04-30-2016, 07:18 AM #6
you need a heated bed - period.
yes there are plenty of filaments that can be printed on unheated beds - but most of them will work better on a heated bed. Adn the best print surfaces work by filament sticking to the hot bed and not sticking when the bed has cooled. Like the printbite I use.
So for $100 more a heated printbed and larger print volume are a bloody good deal.
Go for it :-)
When i looked at the heated bed option it said $10 - NOT $100.
Snatch their arms off :-)
05-01-2016, 03:59 PM #7
- Jan 2015
- 12
05-02-2016, 07:58 AM #8
05-04-2016, 02:29 PM #9
- Jan 2015
- 12
This will be the funny part!!! hehehe.
I already find the manual and it is Ikea like, which I believe will be fun and simple.
I Also started designing a Auto bed lvl to the printer and probably will do more improvements later on as soon as I get used to the printer and to 3d printing !
QIDI Slicer "Plater" is...
