Results 11 to 16 of 16
Thread: power supply question
05-17-2016, 07:59 PM #11
- Aug 2015
- 256
12v is the voltage, this is what matters most--too much will fry your board, too little won't work.
30A is the amp RATING: it's the maximum amps that the power-supply can provide without burning out.
360W is redundant information. Watts are just amps * volts. It's a shorthand to quickly describe how powerful a supply is, but you can just do the math yourself: 12x30 = 360.
The best way I've found to explain volts, amps and watts is to think of electricity like water flowing through a hose.
volts = how fast the water is moving through the hose
amps = How thick the hose is
watts = how much water is coming out the end of the hose (a function of how fast the water is flowing and how thick the hose is).
If the water isn't moving fast enough (volts) there won't be enough force to make your machine work.
If the hose isn't big enough it will burst if the machine trys to draw more water than can fit in the hose.
05-18-2016, 02:05 AM #12
- Jun 2014
- Burnley, UK
- 1,662
Your comparison is wrong.
Volts is nothing to do with anything flowing, it is the pressure that can make it flow. Like a loft tank in your house the voltage is the height of the tank whether any is flowing or not. That is made clearer when you call it "potential difference" rather than voltage. Amps compares to the amount of water flowing.Last edited by Mjolinor; 05-18-2016 at 02:37 AM.
05-18-2016, 02:39 AM #13
- Jun 2014
- Burnley, UK
- 1,662
All forms of energy can be compared to each other, they all have equivalents whether it is a tank of petrol, a tank of water, a battery or a gas supply.
05-18-2016, 03:41 PM #14
- Aug 2015
- 256
It's an analogy, and all analogies are imperfect. Using the speed of water moving is a good description for volts in an active electrical circuit, using your example of potential energy is a good description of a resting battery.
In this discussion we were describing the former not the latter.
Amps relates only to the "amount" in a single moment, not the amount over time.
05-18-2016, 04:54 PM #15
- Jun 2014
- Burnley, UK
- 1,662
The analogy is wrong. You can have voltage with no flow. The correct analogy is that of the "head" of water. A water tank full of water at the top of a building even though the tank has no holes still has the potential to deliver energy as does a battery that has no wires, the potential is there and not tapped.
As I stated there are direct comparisons of equivalents across all energy delivery systems, tehy are more than analogies the are different versions of the same thing.
Maybe some diagrams will help you understand:
http://hyperphysics.phy-astr.gsu.edu...c/watcir2.html
06-09-2016, 06:02 PM #16
- Mar 2016
- 12
wow...so many info............!!!!!!!!!!
