Thread: Portabee GO
03-23-2016, 03:24 PM #1
Portabee GO
Portabee GO is a unique & affordable 3D printer that folds flat to fit neatly in a carry satchel.A truly mobile 3D printer that is simple to operate, and allows you to 3D print anywhere.3D PRINT, ON THE GO
A 3D printer that is easy to use, affordable and folds neatly for transport. You can take your Portabee GO anywhere. 3D print on location with clients and amaze your friends around town.
LET’S KEEP THINGS COMPACT
Portabee GO is the most compact 3D printer to date. Other 3D printers begin to seem like gigantic microwave ovens when compared to the neat profile of a Portabee GO.
PRECISION 3D PRINTING
Constructed from robust aluminum and steel, Portabee GO achieves fantastic accuracy. Portabee GO aims to rival high end 3D printers in precision, without all the bulk.
AUTO CALIBRATION
Bed levelling by hand is a big time waster. We’ve engineered the GO to calibrate itself. The GO automatically detects a level plane before each 3D print, improving your workflow and increasing print accuracy.
TECHNICAL SPECIFICATIONS
TECHNOLOGY
Fused Filament Fabrication
Thermoplastic Extrusion
BUILD VOLUME
12cm X 16cm Y 12cm Z
4.7in X 6.3in Y 4.7in Z
2304 CM ³
139 IN ³
PRINT NOZZLE
0.35 MM
LAYER ACCURACY
50 Micron
0.05 MM
http://3dprintnerd.com/listing/portabee-go/
