02-10-2016, 12:37 PM #1
- Feb 2016
MakerFarm 8” i3v Prusa with Printrboard Electronics Trouble
I have a MakerFarm 8” i3v Prusa but with Printrboard electronics. I have Printrboard electronics instead of the traditional one for the MakerFarm 8” i3v Prusa as the electronics came from an abandoned DIY build I originally did. I gave up on this DIY build and purchased the MakerFarm i3v to i3v Upgrade. Of course I still have the Printrboard electronics.
Everything is hooked up and to start testing I simply clicked on HOME in Pronterface as I am running this off my computer not the LCD interface. This YouTube video shows what happens, https://youtu.be/oOlZiA6nlmc
Hopefully the video is clear enough to show you that I am having the following problems:
- All three axis move in jerky steps not smooth movements to the endstops as in the demonstration video (https://www.youtube.com/watch?v=JVA8VjegmVE).
- The movement is not only jerky in all the axis but also very slow compared to your video.
- The x and y axis movements stop after a few "steps," 7 to be exact, long before they reach the endstops. The z axis stops after about 330 "steps," also before it reaches the endstop
- The z axis does stop when I press the z endstop as shown in the video.
I know I have successfully upload firmware to the new Printrboard from my computer because I was able to change the Configuration.h file to reverse the home direction of the x and y axis by this instead of flipping the connector to the Printrboard from the stepper motors.
I tried changing the potentiometers on these axis to see if they made a difference but this only changed the distance of these "steps."
Interestingly when I originally had this Printrboard hooked up to my homemade 3D printer (before I gave up on it and bought your kit) I experineced the same thing. I assume there is either a problem with firmware settings I loaded onto the Printrboard (though the firmware is the ones that are downloaded from your site for Printrboard) or the Printrboard itself.
Any help would be appreciated.
Which 3d printer for small...
