01-31-2016, 11:38 AM #1
Makerbot 2x estruder wont stay hot for a print
My 2x has a very odd extruder problem. The right extruder works fine. The left will heat up when it should but recently has been cutting out right as soon as it completes its preheat. The change filament function and preheat utility will heat up and maintain the temperature of the extruder. As soon as the printer starts a print, either duel or left extruder only, the heater cuts off. So far I've created different print files from different computers through USB or SD card, exported through different versions of makerbot desktop, and most recently I downgraded then upgraded the firmware. All had no affect on the function of the left extruder. Any suggestions?
02-03-2016, 08:19 AM #2
- Mar 2015
- Slovenia, Europe
- 76
Howdy
Go into General Settings and see if you have Tool Count = double
Go to General setting Preheat settings and see if you have Left ON
02-12-2016, 02:34 PM #3
- Feb 2016
03-18-2016, 05:32 PM #4
That wasn't the fix but you got me on the right path to finding it. It had to do with the newest update desktop update. When you use custom print setting profiles on the 2x fails to heat the extruder when using 3.9.1.
QIDI Slicer "Plater" is...
