Flash Forge Inventor
Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. #21
    cool. let us know how it goes
  2. #22
    Student Reify 3D's Avatar
    Nov 2014
    Location
    Hsinchu, Taiwan
    Add Reify 3D on Facebook
    Hi,
    We will soon be releasing a printer designed for jewelry/miniatures production. It uses an HD projector and has an adjustable resolution from 41.6 microns XY (80x45mm build area) down to 25 microns XY (48x27mm). It has a very smooth and trouble-free peeling method for a professional surface finish. Below is a recent print from our final prototype. It isn't jewelry, but it shows the excellent brightness and focus uniformity across the full 25 micron XY build area.
    Regards,
    Mark
  3. #23
    Nov 2014
    Location
    Hsinchu, Taiwan
    Our customer printed this beautiful ring with Solus (www.reify-3d.com):
    Alloy: High Palladium 18ct White Gold (7.91g)
    Diamonds: 15 x 0.35ct, GIA G VS1 Ex/Ex/Ex
    Print in B9 Cherry:
    - Projector settings: Eco mode, 50% Brightness, 60% contrast, 1.8 Gamma
    - Exposure settings:
    - Slice Thickness: 0.025
    - Exposure time 2500 (ms)
    - 1 Bottom layer at 10000 (ms)
    - Lift & Sequence time 6000 (ms)
    - Z Lift 4mm
    - Z Lift speed 120
    - Z Retract 250
    - Slide Tilt 3
    - Print time: 2 hours 48 mins
    - Model Height including support and long prongs 29.62mm
    Mark
  4. #24
    Engineer ralphzoontjens's Avatar
    Nov 2013
    Location
    Tilburg, the Netherlands
    Follow ralphzoontjens On Twitter Add ralphzoontjens on Facebook Add ralphzoontjens on Shapeways Add ralphzoontjens on Thingiverse
    I am wondering if anybody else has any experience with creating castable models with either the Solus DLP or B9 creator printers, and what the capacity is per day of printing.
    So one ring takes almost 3 hours, but how much time would a full build volume take? I would estimate, given that the Solus could print 30 rings in one volume, it to take a full day.
  5. #25
    Staff Engineer
    Jan 2014
    Location
    Oakland, CA
    I've never even seen a Solus in person, but I've been using a B9 for a while now. It's hard to say exactly how long an unknown print would take, but projection printers are pretty fast compared to machines that need to trace the whole part on each layer. It doesn't really matter that much how much stuff is on each layer, since the whole slice is exposed at the same time. The main thing that takes time is the peel/raise/wipe/reset cycle. The time that will require is determined by the height of the part and the layer thickness.
