Results 3,901 to 3,910 of 4110
01-21-2017, 06:11 PM #3901
- Jan 2017
Interesting to know, I didn't find that info anywhere. It's only drawing 0.6% of the 375w PSU's reserves (converter is >85% efficient at 2w) so I'm not concerned. It will also let me string up more 12v LED strips if I choose. I've tested them with 48 LED's for a few hours w/o issue and several lesser applications. If I really need more power I've got some slim 750W HP PSU's that I can put in series for 24vdc. Individually they're about 2/3 the size of that "Meanwell".
What I'm liking more and more is the rotated switch, it wasn't easy to access on my desk.
01-21-2017, 07:34 PM #3902
I rarely turn my printers off, and if I do I switch off the UPS they are plugged into.
01-21-2017, 08:29 PM #3903
- Jan 2016
- 81
I have a question for all the QIDI Guru's out there, (Yous guys)
I have found that I need to replace my extruder motors, and they are as follows:
42HB34F08AB rated at .8 amps.
I have found motors that meet most all needs except they are either 0.4, 1.2, or 1.5 amp rated....
Will this matter, or damage anything if I go up higher than .8 amps? Can the power supply handle it? Should I go with the lower 0.4?
Also, most of the ones found are a little longer at 40mm, versus the 34mm of the stock, will this effect anything??
Thanks in advance!!!
Also if anyone has a link to a replacement extruder motor that is pug and play let me know!!!
01-22-2017, 12:08 AM #3904
- Jan 2016
- 81
Do you have a link to this?
01-22-2017, 12:09 AM #3905
01-22-2017, 03:32 PM #3906
- Sep 2016
- 80
So, question for everyone. I've just finished a weeks-long printing of a deluxe Catan board. The reason this matters is because I'm printing fairly flat, relatively thin pieces. Not that thin, but thin enough. Basically, various hexes from this:
http://www.thingiverse.com/thing:1238980
Anyway, long story short, as I finished each piece I found that I couldn't get my blue tape up off the bed without it tearing around the pieces and, therefore, still leaving the pieces attached to the bed (albeit, with a piece of tape under them doing me exactly no good whatsoever).
So, the two ways I found to get things loose were:
Heat the bed once a print was finished, and then use my putty knife to pop the piece loose. Of course that meant I was actually deforming my piece. At best, I'd take a notch out of it as I got the knife under, at worst, I'd end up basically curling the side of my piece.
Heat the bed once a print was finished, and then detatch the tape from the edge of the bed, and using that, pry up the piece using the tape itself as the putty knife (basically). Sometimes this would work fine, if the piece popped off. Sometimes it would work poorly, if the piece did more of a slow bull and got a bit cupped. And sometimes it went terribly, and I would have the tape rip around the piece and I'd have to go back to Plan B with the putty knife.
So, I'm not looking for ideas on how to get prints to stick, because from what I've seen enough work leveling will get you there eventually. My issue is getting the pieces off the bed without damaging them. Any suggestions?
01-22-2017, 04:40 PM #3907
- Apr 2015
- Northern Ohio
- 198
Glass bed, glue stick if prints are not sticking, freezer if the prints don't pop right off after cooling.
01-22-2017, 05:11 PM #3908
- Sep 2016
- 80
So, just something like this: http://www.ebay.com/itm/3D-Printer-H...3D171977598512
connected with these: http://www.thingiverse.com/thing:1596076/#files
Or is there a better choice?
01-22-2017, 05:52 PM #3909
- Apr 2015
- Northern Ohio
- 198
I use a similar setup on my ff machines but read the fine print on the glass. It states the size may vary by 1-3cm. That is way too much for those clips to work. Look for a local glass ahop and have them cut one to your specs.
01-22-2017, 06:07 PM #3910
- Sep 2016
- 80
Actually, with some more research I think I'm going to try some regular picture frame glass with these clips, unless someone cautions against it: https://www.thingiverse.com/thing:570406
Which 3d printer for small...
