Flash Forge Inventor
  1. #1
    Student
    Jul 2015
    Location
    B01, Lakeside 1 Klagenfurt, Austria
    Add 3DMarkt on Facebook Add 3DMarkt on Google+
    Lightbulb Wanhao Duplicator 5S Mini - 3D Markt
    • Best Layer-resolution! 0.02mm per Layer
    • Extraordinary Printing Speed- 300mm per second!
    • Massive Building Volume- 295*195*205mm!
    • Extremely Portable
    • 1 Year Full Factory Warranty
    Capable of printing up to 12 litres of volume, the Wanhao Duplicator 5S Mini may exceed the customers’ expectations as it is equipped to print larger amounts than what its name may suggest. Because of its small size, the printer is easily transported and makes for a perfect desktop placement. With an exceptional resolution of 0.02mm, the Duplicator 5S Mini provides the user with a more serious detailed 3D Printing experience and the ability to produce a range of promising goods. Functioning at a high performance, the patented extruder avoids any interruption problems that may occur and in turn allows the user to print with ease and efficiency. The Duplicator 5S is fitted with an all steel framework, which gives it a modern sleek finish and promises a long service life. Finally the ability to print big and fast in a limited space has arrived! Don’t miss out!
    Advanced features:
    • Huge building volume: 295*195*205mm!
    • One of the fastest 3-D printers in the world- up to 300mm/sec!!
    • Layer thickness: Best resolution in this price class! 0.02 – 0.4 mm
    • Fitted with a high performance, patented extruder. No clogging problems
    • Print from the built-in memory and avoid interruptions caused by your PC or USB-cable
    • All-steel frame work, super long service life
    • Industrial-grade motion system, high stability and precision
    • Speed: 20 – 300 mm/s
    • Positioning precision: 2.5 micron on Z axis, 11 micron on XY axis.
    • Overall dimensions: 460 x 530 x 480 mm
    • Shipping weight: 25 kg
    • Linear ball bearings
    • 4x20 LCD character display and turning and press control pad
    Specifications
    Printing technology FFF Fused Filament Fabrication
    Extruders 1 Single Extruder
    Interface Print with SD Card or direct via USB Port
    Build volume 295 x 195 x 205 mm, about 12 l
    Layer resolution 0.02mm - 0.4mm
    Print speed 20-300 mm/s
    Position precision X,Y Axis 0.01mm
    LCD Display 4x20 LCD character display and multi-direction control pad
    Operating nozzle temperature Recommended Maximum 230 C
    Platform temperature NA
    Supported materials Prints PLA, PET
    Filament diameter 3.0+-0.1mm
    Connections USB, SD Card slot
    Chassi Extreme XV Rock Steel structure
    Mechanical Property
    Overall dimensions: 295*195*205mm!
    Shipping Weight: 25kg
    Precision ground Core XY.
    Snap-on, snap-off filament assemblies
    Full Extreme steel Structure
    SOFTWARE: WanhaoMaker
    Compatibility: Linux, OSX, and Windows
    Print from SD card or over USB
    Input file type: STL, gcode
    Materials
    Works with PET and PLA.
    Filament diameter: 3.0 mm
  2. #2
    Engineer ralphzoontjens's Avatar
    Nov 2013
    Location
    Tilburg, the Netherlands
    Follow ralphzoontjens On Twitter Add ralphzoontjens on Facebook Add ralphzoontjens on Shapeways Add ralphzoontjens on Thingiverse
    From what I see after unboxing it yesterday, this is a fantastic printer. So far I ran tests with a low-poly model, organic sculpture, a mechanical part and a flexible set of parts, in all four it excels. It is all steel so will remain stable for a long time. Very suitable for professional use, especially architects and industrial designers who need rapid prototypes. The microprocessor is an Arduino mega so very good and easy to program. The printhead has room for up to three extruders, which can be developed quite cost-effectively.
    Make sure to install stable releases of firmware, also there is software to convert gcode to the proprietary idea (.i) format Wanhao works with.
    The Wanhao maker slicer produces great results and will generally have all the settings available you need.
    I recommend this machine to everyone.
  3. #3
    Jul 2014
    does it have a heated bed ?
  4. #4
    Nov 2013
    Location
    The Wanhao HBK is $225, and components for a dual extruder cost $210 total.
    I think they made a good choice offering the basic configuration. The only error I got so far was the result of beta firmware, for the rest it has been printing wonderfully.
  5. #5
    Jul 2014
    Hbk ?
  6. #6
    Nov 2013
    Location
    Yeah, heated bed kit so all in all this printer is modifiable. So far I found one person who made this into a dual head printer which took more time than with most other printers, but it worked in the end!
Tags for this Thread
