Results 1 to 8 of 8
07-02-2015, 12:01 PM #1
Having problems scanning my 2nd part
For my second part, i wanted to test an object with sharp edges and precise measurements, to be able then to measure the scanned dimensions .
But i'm running into trouble, i cannot get a clean scan, see pictures below.
The object is a metalic L shape bracket.
I tried various settings for brightness and level of details, i also tried with the object in different positions.
Any advice appreciated,
07-02-2015, 01:46 PM #2
- Jul 2015
- Calif.
- 26
Powder it with talc it should then scan fine. if not you can also use spray paint primer.
07-02-2015, 02:10 PM #3
ok, i will try that tomorrow.
07-03-2015, 03:54 PM #4
i powdered the part with talc, but unfortunately i don't see much progress.
07-04-2015, 02:13 PM #5
07-04-2015, 03:38 PM #6
07-05-2015, 11:32 AM #7
Actually, it's not the scan that fails, but the alignment.
I can scan properly in free scan mode, the first scans comes out nicely, the second one as well, but when i ask the system to align them, this is where it starts to get ugly.
Advice on proper alignment would be really needed here.Last edited by Hugues; 07-05-2015 at 02:47 PM.
07-06-2015, 02:44 PM #8
Success !
Definitely overlapping at least 1/3 with the new scan area is helping a lot, as advised by Shining 3D in another thread.
I managed to free scan a part on my bike, about 400mm by 400mm, low or medium detail setting, i forgot to check, but not high setting.
I used around 20 scans maybe, it took me around 1 hour, most worked with automatic alignment, except for one tricky part on the left side, i had to manually align, but despite this the system did not manage to align the part, so i deleted that last scan and came back to this problematic area from another side.
And the dimensions are pretty good, measured 347 mm between 2 screws, reality is pretty much 347mm, +/- 0.5 mm maybe.
Cool ! scan can be seen here, 25 meg only stl file:
http://www.thingiverse.com/thing:913581
Now, one cool new function would be to be able to stop a scanning session, save it (in whatever internal format you use) then re-open it later and continue the scan. This way we could scan quite large parts, like my whole bike :-)Last edited by Hugues; 07-06-2015 at 03:00 PM.
QIDI Slicer "Plater" is...
