Results 1 to 10 of 10
  1. #1
    Student
    Dec 2014
    Location
    Ft.Worth, TX
    Printing off-center
    I have the FlashForge Creator Pro with Sailfish 7.7 I'm using Replicator G for the slicer. I have a problem objects print off to the side. It isn't a big deal with small objects, but with larger ones it ends up running off the side of the build plate. It makes no sense. Unfortunately, this limits the objects I can build to about 3 inches in size. I have googled for this issue and so far not come up with anything. Can anyone offer any advice?
  2. #2
    Technician
    Apr 2015
    Location
    State of Confusion
    Add Nargg on Thingiverse
    Can you post pics of what you are seeing? I think I know what you mean but want to make sure.
  3. #3
    Student
    Dec 2014
    Location
    Ft.Worth, TX
    Quote Originally Posted by Nargg View Post
    I don't have a photo.. But here is a little drawing to illustrate the issue. Also, when in Replicator G it shows the object in the direct center. But it doesn't print out that way.
  4. #4
    Technician
    Apr 2015
    Location
    State of Confusion
    Does it start printing there, or does it slide off while printing? If the latter, then you need to look into plate adhesion methods. If it starts printing off, then you're settings in Replicator G may be off. Also, there are some really buggy versions of Sailfish, so look there too as a possibility.
  5. #5
    Student
    Dec 2014
    Location
    Ft.Worth, TX
    It actually starts printing there, even laying down the raft. And it goes right off the edge and the plastic just oozes all the way to the bottom of the machine.
  6. #6
    in the flash forge software there is a option to put the model in the center not sure if there is in the rep software.
    if not play with the z axis i think it is to move it over .
  7. #7
    Technician
    Apr 2015
    Location
    State of Confusion
    Lots of slicers out there. Including the one that came with the FlashForge. Try a different slicer and see if you have the same problems.
  8. #8
    So how do I center my print on the print bed more?
  9. #9
    Engineer-in-Training
    Aug 2015
    Check your bed size settings in your slicer, they could be larger,
    or check if the X-Y limit switches have been moved.
    Does the print head sit at the corner of your bed, after homing ?
  10. #10
    Jul 2014
    one thing to check is that your printing start point is not set to: 0:0 as that is the top right corner.
    For the bed size on the creators it should be: 110:75 (or the other way round). Basically you divide the width and length of the bed by 2 for your X & Y start point and that's your centre point.
