Thread: Help with printer
05-30-2015, 03:46 AM #1
- May 2015
Help with printer
Any one know why there is reddish plastic discharge from the extruder? I have set the temperature to 220 and retract length to 10mm on prusa i3 while printing PLA. Has anyone encountered this before? Any solution?
05-30-2015, 01:07 PM #2
- May 2015
- 30
Because your using red pla? Jk, idk. Pictures sure would help.
05-30-2015, 05:57 PM #3
- Aug 2014
- Montreal, Quebec
- 576
PLA is notorious for oozing. Print at lower temp to lessen the problem, but remember, PLA is PLA, it will ooze!
05-30-2015, 08:56 PM #4
Since I would assume you have recently used red filament, not sure what else you'd be expecting.....
You should only worry about discharge when it's greenish white.
AI generated 3d models -...
04-12-2024, 11:54 AM in 3D Modeling, Design, Scanners
