Results 1 to 5 of 5
    Molecular Manufacturing is Here
    Researchers at the University of Illinois have created what may end up being the future of 3D printing. In a device they call a 'molecule-making machine' they are able to synthesize literally billions of compounds from hundreds of small molecules. Currently the technology is in the process of being improved after a major investment from a company called Revolution Medicines. Burke, the lead researcher and chemist says that compounds can already be created with the device which humans have never made. The machine, dubbed a 3D printer, of chemistry could prove invaluable in the discovery of new drugs as well as new chemical based technologies. More details on how this incredible machine works can be found here: http://3dprint.com/50777/molecular-3d-printer/
    Below is a picture of this new 3D printer:
    Technologist
    Mar 2015
    eezitec.com
    Follow raysspl On Twitter Add raysspl on Facebook
    That looks both imposing & menacing, in a good way I suppose.
    This looks like a mad scientist's machine. I'm guessing it's a bunch of syringe-like extruders connected by plastic tubing to a print head - actually, judging from the tubing into the flask, they may be individual heads. More like a paint color mixing machine. Undoubtedly a big leap forward for chemistry - it will be exciting to see what develops.
    Dr Sinclair has discovered a way to reverse aging with a chemical called NMN (nicotinamide mononucleotide) it cost like 300,000 for small amounts Can this machine make it much cheaper? How much could it print in day and costs for that?
    Since I'm investigating molecular manufacturing
    (or atomically precise manufacturing APM - the newer name)
    I think I can clarify a bit how this development brought up here ties in into the big picture of APM.
    First some minimal details about what this "molecule making machine" here is actually all about:
    http://www.scs.illinois.edu/burke/fi...32_Science.pdf
    The the "Suzuki coupling" is used to make carbon carbon bonds
    https://en.wikipedia.org/wiki/Suzuki_reaction
    like so: ...≡C-B(OH)2 + Br-C≡... - > ...≡C-C≡... + waste
    To continue after a first reaction one needs pre-delivered
    building block molecules that are at least double capped
    like so: Br-C≡...≡C-B(OH)2
    But this would self polymerize. That is it would form "infinite" chains.
    So the solution found was to temporally cap (chelate) the boron end with a molecule called-
    "trivalent N-methyliminodiacetic acid (MIDA fro short)" like so:
    http://www.sigmaaldrich.com/chemistr...boronates.html
    For purification it was found that the MIDA caps on the growing product molecules can be locked/released to/from silica particles by different solvents.
    Limitations of this process that I'm not clear about are:
    # How small/big can the pre-delivered building block molecules be?
    # The pdf-document says that they can create loops. How? How tight can these loops be? How close can they be together? (I highly doubt big polycyclic diamondoid cages are possible. Not to speak of strained ones.)
    # Can this be done hierarchically or only serially? (Hierarchically would extend scalability a bit.)
    Limitations that are obviously present:
    Since this is conventional chemistry and not mechanosynthesis the yields are low and the error rates are high. Every synthesis step can easily have losses in the single digit percentual range. Thus this is only suitable for small molecules (as the work says itself) and does not scale up very far.
    In light of early APM I suspect this could be useful for:
    # The synthesis of light activated "motor molecules"
    # The synthesis of novel side chains for foldamers (for boosting stiffness & symmetry)
    # Maybe short self-assembling strands (like in structural DNA nanotechnology that exclusively uses short oligonucleotide strands)
    With early APM I'm referring to "Coarse-block APM systems" page 33:
    https://energy.gov/sites/prod/files/...%20Drexler.pdf
    I'm not referring to what is shown in the INFAPM workshop video! That video is (as I see it) just about the "System-level tech demos" dead end in the diagram.
    While the "molecule making machine" here certainly is a major step for medicine I'm not sure about in how far this will tie in into the bootstrapping of advanced APM.
    I'm writing a website about APM atomically precise manufacturing:
    http://www.apm.bplaced.net
    As a side-note: I certainly wouldn't count that molecule making process as a form of "3D printing" just because it's additive manufacturing.
    # It handles discrete parts. That is usually called pick and place assembly but ...
    # There is also no active positioning involved whatsoever.
    It's more like going from painstaking chemistry-research to straightforward chemistry-engineering. But the term "chemical engineering" is already taken.
    "Programmable chemistry" maybe ... ?
